2001 f 150xl v6 . please help. rotors..
im trying to buy some front rotors for the truck im gonna replace pads aswell. the truck is rear wheel drive. its a v6 2001 xl. what rotors are on the front wheels the ones with holes that go over studs or the rotors that come with studs sticking out of them? I cant seem to find my answer on google. and I can get to the truck until the weekend to look at it.. thanks
so replacing these isnt just a cottor pin and 36mm socket?
That's all it is.
It's conventional old school. Remove the caliper, remove the cotter pin and nut, pull the rotor/hub off, outer wheel bearing comes off into your hand, inner wheel bearing comes out after you pull the grease seal.
