Brake works but slowly going down toward floor.
So I have a solution to this issue
Before anyone "informs me" how old this post is, I'm aware of it's age. After re-reading it I saw no concrete answers offered, only more suggestions where to look. I had commented that when I solved my issue I would post the results, here they are:
After coping with my own "pedal sinking to the floor" issue for quite some time now as I previously mentioned in the comments above.
Last week my truck developed a leak at the ABS unit, I located a used unit with a warranty from a local salvage yard for $150. A new unit from the dealer is well over $1000 and while I like my truck I am not willing to spend 1/3 of it's value to fix the brakes.
My brother and I installed it along with new lines from the master over the weekend.
I'm happy to report that there are no more leaks, and the mysterious sinking pedal is gone!
If I had to guess what was wrong, the ABS had an internal leak causing the pedal to sink without losing fluid. Eventually it got bad enough to leak out of the unit.
