Which tire size to choose!?
Hello I have a 2006 f150 4x4 that has a 2 inch leveling kit. I have 20x9 wheels with a +13 offset. I am torn between what size tire to get. I like the 305/55r20 size but am worried they will rub. If they rub I'd go slightly smaller and get the 295/55r20 size. I don't wanna lift it and don't want severe rubbing when turning. Any info or advice would be greatly appreciated! Thank you!
I see tons of people on here running 20x9 with +18mm offset(yours stick out slightly more than that) and they are running 305/55r20's or 33x12.50's with no rubbing with NO LEVEL. If you have a level, you should definitely be good to go.
I am actually looking myself at running 33x12.5 tires without a level...........
Brian
Brian
