installed 275/60R20, wheel spacer question
275/60R20 on stock wheels, just put these on. Small but noticeable difference from stock tires. Also since this is a 33" tire from what I read on here this is the biggest I can go with no level anyway, I might level later with larger tires but not now.
My question, I like more of the "bulldog" look, can I use wheel spacers to do this? How much can I use on the stock wheels/studs? I'm thinking 1.5" or 1". Any suggestions?
Thanks.
Thanks.
Thanks.
Thanks.
For wheel spacers, 1.5" will be needed for no stud trimming, and hub centric ones are the only ones I would use. I run Bora 1.5" spacers on my 20x9 wheels with 295/60-20 mud tires, there is front end up since they are almost a 35" tire, but the spacers are a quality product. Just need torque checked every oil change.
