Plasti dip
Old 10-20-2014, 05:03 PM
BigBuckMafia's Avatar
Plasti dip
Anyone ever use plasti dip on there wheels ? How does it hold up ? I'm thinking about using it on my wheels!
Old 10-20-2014, 07:23 PM
SFM's Avatar
SFM
SFM is offline
My son has it on his g35. Self-applied, not sure what brand, but he is constantly touching it up. Seems to come off where the tire and rim meet.
Old 10-20-2014, 10:32 PM
I heard if you later its lightly like 3 to 4 times and you allow each coat to sit for 4-5 minutes they will be okay. I'm wanna try it but I don't want my rims looking like crap. I figured if they don't come out good I could always just peel it off
Old 10-20-2014, 11:18 PM
Toyz's Avatar
Tons of people do it. Including myself. I used a whole can on each rim. Clean them good before hand. Make sure they are dry. Tape off at the tire edge with 1" tape and go to town. It's important to get the base layer down right without loading it up to heavy. Once the base layer looks good just keep putting layers every 5-10 minutes. The thicker the better.
I have since had experience with repairing big tears. Went up over a curb after being rear ended and the tire folded over the rim peeling off an area about 10" wide. I took a razor and cut it to a clean edge then went about putting new layers on blending around the whole rim a bit but mostly concentrated on the peeled area. After 10 coats or so you couldnt even see the edge of overlap and the patch came out perfect. Very happy with how it patches. Can't beat it for $6 a can.
Old 10-20-2014, 11:21 PM
SFM's Avatar
SFM
SFM is offline
His rims DO look pretty good, at least for about 3 weeks at a time. He does peel it off and start over if they get too nicked up. Pretty simple to spray on and remove. He keeps wanting to spray mine but I haven't bitten yet!
Just keep in mind it is a fragile covering. layering them helps, but anything you rub a rim against will scratch it off. I've even seen the spray gun at a car wash cut thru it.
Old 10-21-2014, 02:29 PM
AJ@tirerack.com's Avatar
Former Sponsor
I plasti-dipped my wheels on my track car and had great success with it. I used off the shelf plasti-dip from Lowes, cleaned the wheels really well using Simple Green and let them sit in the sun for a few hours prior to applying. Several lights coats is also a key.
The wheels were 15" and I used about a can and a half. It went through the car wash a few times, and lots of heat from track use. Never once did I have any issues with it.
Rather than masking the tire, I stacked the larger size index cards between the tire and the wheel and pulled the cards off prior to the plati-dip drying. You have to pull the tape or cards every time you apply otherwise it will adhere itself to the index card/tape and the wheel and when you pull the tape/card off, the finish will come off with it.
Old 10-21-2014, 07:47 PM
Do the make it in a class black or only mate black ? That's my only next set back. Can I see pictures of how it looks. I still don't know what to do yet.
Old 10-21-2014, 09:07 PM
Toyz's Avatar
They make a glossifyer you can apply afterwards
Old 10-22-2014, 02:08 AM
BrazenC5's Avatar
I plasti-dipped the machined centers on my rims. Did 4 light coats per wheel allowing at least 30min to dry in between coats...still holding up very well, no tears / chips after 3 months.
Old 10-22-2014, 06:58 AM
Does that gloss coat give it a nice glossy look ? See I have **** cepik d2 I wanna make all black !
Old 10-23-2014, 07:54 PM
loser54023's Avatar
if you go on youtube and search dipmycar, there is a guy that does this for a living and shows you how. you can also go on dipmycar.com and buy whole kits for spraying. they do whole cars with that stuff.
Old 10-23-2014, 08:24 PM
Yes. The glossifier worked pretty well when I did my old mirror caps.
Old 10-23-2014, 10:27 PM
I'll check them out. Anyone know an app I can get to take a picture of my truck and color the wheels black so I can see how it'll look before I buy this stuff and spray them ?
Old 10-23-2014, 11:47 PM
Assuming your truck isn't wildly modified, Google should be sufficient for getting an idea what it'll look like. PD is already the "let's try this out and see how I like it before I'm stuck with black wheels" product haha.
Old 10-24-2014, 07:05 AM
Yeah. That's also what I was thinking, but I also thought to just buy legit black rims.
Quick Reply: Plasti dip
