2002 FX4 17" alloy wheels losing clear coat
A cheap solution is to sand the wheels and spray on a clear coat. Ensure that all of the old clearcoat that is peeling has been removed.
This may leave sanding marks in the aluminum if the clear is gone, so you may want to spray a primer and base coat of silver (or whatever color) after sanding.
BTW, anyone know how to remove those pesky water spots (also there before I owned the truck) on the paint. I use Maguire's cleaner wax, maybe I need to use something before I wax it???
