WOW What a lot of brake dust on my newer truck
There are 2 things that i really hate and they are bad wipers that streak and brake dust on my wheels.
This question is about brake dust.
I went from a 1999 F-150 XLT to a 2008 Lariat FTX Tuscany.
I would get brake dust on my 99 chrome wheels but nothing like what i get on the 08 chrome wheels. It really builds up fast, is there any reason for one generating more dust than the other?
Is anything bigger on the 08 than the 99 to create more dust?
Any solutions?............What are you guys seeing??
Is there any difference in dust with semi metallic or metallic pads versus ceramic which i am now reading about or is it personnel preference one you get away from OEM?
Use the search button at the top, do searches on Wagner ThermoQuiets, semi metallic and ceramic and see if you don't get more senders than you need. I don't think you can go wrong with any good brand, either semi metallic or ceramic. Even the Ford replacement is said to be dustless. It's just the soft OEMs that are a problem.
I asked a guy at Meineke by my house because i was curious about a price and he told me the truck probably already has ceramic pads.
Is this true? its a 2008, in reading everyone's responses i am sure i can find someting that has lees brake dust then what is occurring now.
He also said $199.00 that sure seems high for front pads?
Fords are notorious for brake dust on the OEM pads. Swap out to Semi Metallic pads and the problem goes away...
FWIW, a lot of folks swear by the Wagner Thermo Quiets, I tried them and did not care for them. I am using PowerStop pads right now, have used EBC Greenstuff 6000s in the past. When I wear out the current PowerStop pads I will likely throw a fresh set of Greenstuffs back on...
I've been expecting the dust on my 13 with only 6500 miles on it, but it's yet to show any, even on the inside of the wheel... Well, lets say "significant" amount on the inside..
I'll be rotating the tires soon, so that will really tell me what's going on, but so far, I'm pretty impressed with the OEM's..
I too go with a decent semi metalic pad when I need them.. I did like the Thermo Quiets I had on the 97..
Good luck!
Mitch
Good luck!
Mitch
