stock wheel offset vs. backspace
I keep reading that the stock 18x7.5" wheel has a BS of 5.5".
Yet I've also read that some people say the offset is 40mm.......a few others are claiming that it is 44mm?
When I plug these #'s into the calculator.... http://www.rimsntires.com/specs.jsp
to come up with a stock backspace of 5.5" I need to use an offset of 32mm.
40mm or 44mm equates to a backspace of 5.8" to 6.0".
My questions is does anybody know for sure?
If it's a backspace of 5.5", it sure as heck can't be a 40 or 44mm offset?
A 7.5" wide wheel with zero offset means the hub face is 3.75" from either side of the flange where the bead seats (2 X 3.75 = 7.5). Figure the lip is near 1/4" thick, so call it 4" from back face of wheel.
Offset of 40 mm means the hub face is 40 mm from the zero point. 40 mm is about 1.57" (1 inch = 25.4 mm, so 40 devided by 25.4 is 1.57). 1.57 plus that 3.75 is very nearly 5.32" from the wheel flange where the tire bead seats.
Offset of 44 mm means the hub face is 44 mm from the zero point. 44 mm is about 1.73" (1 inch = 25.4 mm, so 44 devided by 25.4 is 1.73). 1.73 plus that 3.75 is very nearly 5.5" from the wheel flange where the tire bead seats.
4mm difference may be the difference between the measuring from rear outside lip versus calculating from inside the rim flange?
32mm devided by 25.4 is 1.25", added to that 3.75 is 5 inches back space.
If NEGATIVE offset, meaning the hub face is closer to the back of the wheel ..... subtract the offset from that 3.75".
Look here .... but understand that when a wheel is said to be 7.5" wide, that's INSIDE the rim flage to INSIDE the rim flange as the tire sees it. When measuring from outside rim flange you'll see 1/2" or more greater measurement. They often draw diagrams showing to outside cause "they do".
https://www.rsracing.com/tech-wheel.html
Hey GA4x4sxrew, I have a 2004 f150 supercrew and I just bought 33x12.50x18 and also fuel offroad hostage rims with +1mm offset with 5.5 backspace. Will these tires fit Good without rubbing?and how far will they stick out? Thanks!
I'm getting ready to swap out my factory 18" XLT rims with the factory 275/65-18 tires, for some **** Cepek Gunmetal 7 rims in 17x9. Backspace is 5.0" and offset is 0. Going to add BFG AT's in 305/65-17. This will all be with a Rancho Quicklift and replacement 3" blocks in the rear to maintain rake.
Thoughts?
Thoughts?
Thoughts?
Thoughts?
Here's what the 295x70x17's looked like.
I had the 295x70x17 Toyo MT's on my '04 Lariat. They were on 17x9 with 0 degree offset American Racing Craters. 33.5x12 and fit perfect on these wheels.
I think your wheels and tires will look good Todd!
