Home Discussion Forums Photo Gallery Vendor Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Ford & Industry News Vin Decoder Advertise with us
Go Back   F150online Forums > Powertrain & Mechanical > Wheels, Tires & Brakes
Sign in using an external account
Register Forgot Password?
Look for a USED Ford F150
Carsdirect.com
Thread Tools Search this Thread Display Modes
Old 06-11-2010, 04:13 PM
Garage is empty, add now
Vehicle: 1998 Ford F150
right front wheel getting very hot
Last week when i got out of my 98 5,4, 4wd truck after driving 15 miles, I discovered smoke from the right front wheel and a very hot rim. As i got to think of it, my truck seemed unwilling to shift up in gear, when i drove it, as if something was holding it back.
Anyone on this great forum have any ideas of what might be the problem.
And another question. I need parts for the truck - breaks, oilfilter, airfilter, starter, taillight. Living in Denmark, parts are almost impossible to get. Anyone who knows dealers shipping oversea.
Appreciate any input
thanks
Prastholm
Old 06-11-2010, 04:24 PM
Vehicle: two 2003 F-150s
Send a message via AIM to Patman
it sounds like the hub bearings went out on it, jack it up and try to spin it by hand. Take the brakes off and try and spin it again and see what happens.
did you have any kind of squealing or noises or vibrations when it happened?
Dual Bullets X Patman LED tail lights X Custom Sub Box
Reverse Fogs X 5/7 Drop X Jmod X Console Shifted
Quote:
Originally Posted by Raoul View Post
Under my umbrella
ella ella ay ay ay
Old 06-11-2010, 04:27 PM
Mine was doing the same thing, it was the Caliper, so I changed them Ok now! It's also a good idea to change the rubber hose because of the excessive heat could make it weak.
Old 06-11-2010, 04:29 PM
2002 Ford Explorer
My Garage
Vehicle: 2004 Ford F150
It sounds like your brake caliper is sticking. I would recommend a new caliper and hose along with bleeding the brakes.
Old 06-11-2010, 04:41 PM
2009 Ford F-150
Vehicle: 2009 Ford F150
It sounds like there is a problem with the caliper. If you change it you'll most likely need new rotors and pads also. If you had them hot enough to cause smoke the rotors may have warped and the pads may be glazed from the heat also.
Old 06-11-2010, 05:19 PM
my english language has some lacks. Could you please explain the word HUB. I suppose it´s short of something.
No noises or vibrations. Just that feeling that something was holding the truck back. I feelt a change in the brake pedal. the movement of the pedal got shorter than before the problem. Perhaps due to hot brake fluid?? Have not tested since in turned cold again
Old 06-11-2010, 05:24 PM
hub is the the 4x4 equivalent of spindle/wheel bearings on a 2wd
Based on your latest description i agree with others thinking that its probably an issue with the brake caliper on the passenger side
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
F150online - Archive - Top
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Contact Details
