275/65R20 vs 285/65R20 on Leveled 08
Yes they are 10ply Tires. I don't think they ride harshly at all. I don't think they make a non E rated BFG KO. They have a decent sidewall which handles bumps in the road better against the stock pirelli's . I run 45 psi(BFG recommended for the F150) which is no where near the max 80 psi where they probably would ride rough.
Yeah, but in the '09 you've got 6 speed tranny, so who cares? A lot guys do this with the 4 speed, so it's all good dude. I don't think anyone regrets it when they upgrade their tires. I know I didn't.
Having the six speed actually raises my concern about hunting for a gear at highway speeds. Currently I am only turning 1500 RPM at 60 MPH. I don't want the truck to drop into fifth or fourth on each hill. I know that I could have a custom tune address this if it became a problem though.
I have the 285/65/20 BFG AT's with a 2.5" level on my '06 with stock 20's
Very little rubbing. So far, it has only happened when parallel parking. And the tires are only hitting the plastic (lower) part of the bumper. If the radio's on, I don't hear it. I haven't really been "off road" yet...but I'm headed to Moab next week!
I just got new 20" wheels and am about to have LT285/65R20/E BFG AT T/A KO tires installed on my 2004 F150 FX4 SCrew. Using load inflation tables from BFG, and formulas available on the internet and from 4WD periodicals, I calculated the appropriate tire pressure at just under 35 pounds (I'm upgrading from the stock LT275/65R18/C). May I ask what pressure you ended up using in your tires? How was the ride/wear with that pressure? Any words of wisdom about these tires? Squirrely in the rain, etc? Thanks in advance for your assistance.
Mark
i dont think 275/65/20 will go on a stock truck..and LEVELing kit means LEVEL..so whatever it takes to get level, i believe 2 1/4 inch on those trucks
DO MOAB! It'll be worth the trip...I promise.
