F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Wheels, Tires & Brakes
Wheels, Tires & Brakes Click Here
Thread Tools Display Modes
Old 11-06-2009, 08:15 PM
Vehicle: 2004 Ford F150 FX4
Bleeding Brakes ??
Is there a write up or anything that can show me how to bleed my brakes. I am going to change my brake pads as soon as i get a chance i want to bleed the brake fluid too....(which brand fluid should I use?)
So does anybody know where I can find a write up or video??
Thanks in advance!
Thanks Mblouir for the sig
2004 5.4L FX4 Supercrew
PHP Gryphon
Old 11-06-2009, 08:41 PM
Vehicle: 2004 Ford F-150
Send a message via AIM to DarrenWS6 Send a message via Yahoo to DarrenWS6
Why exactly do you want to bleed your brakes when your only changing pads? It should be good for quite some time from now. How many miles do you have?
2004 Ford F-150 XLT Supercab 5.4L 4x4
Appearance: Painted Headlamps/Fog lamps, 20% Tint
Performance: PHP Gryphon 87 Perf, 2.5" True Duals X piped, Rear Cats Deleted, Magnaflow 11" Bodies, Magnaflow 4x18 Rolled Tips.
Suspension: Bilstein 5100 Leveling Struts & Rear Shocks, 20x9 XD Monsters, 33x12.5 Toyo M/Ts
Videos: Start Up, Revs, Driving. Fly-By Sounds Burn Out Video Interior Sound/Drone Tunnel Carwash Rev
Old 11-06-2009, 09:03 PM
63,000....do I not need to bleed them??
PHP Gryphon
Old 11-06-2009, 10:06 PM
I would say no, maybe wait until 100k. If your brakes are functioning properly then all you should need to replace are your pads.
Old 11-06-2009, 10:13 PM
Vehicle: 1998 Ford F-150
Send a message via AIM to Raptor05121 Send a message via MSN to Raptor05121 Send a message via Yahoo to Raptor05121
when i replaced my pads one of my calipers stuck so i had to remove the brake line to compress it.
bleeding the brakes takes two people. one inside the cab and one outside. there is a litt nut or hex bolt on the caliper that needs to be loosened. basically put your wrench on it, have the person apply the brakes, and you crack the nut. the pedal will go to the floor, DONT RELEASE THE BRAKE PEDAL. close the nut. repeat. do this until all the air is gone and it squirts out fluid.
we use DOT-3 fluid
4.2L V6 - M5OD | 16" Dual Efans | 2" Drop Shackles | K&N Series-77 | Port & Polish TB
Bent Frame Mod | Custom Down-Turned Bumper | Accordian-style bed flooring
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
