F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Wheels, Tires & Brakes
Wheels, Tires & Brakes Click Here
Thread Tools Display Modes
Old 11-06-2009, 04:33 PM
Tire Circumference Help!
Just got some new cooper stt's and need help adjusting the tire size for my Gryphon. They are 33x12.5x20. I cant seem to find my manual with the formula to convert to mm. Thank you!
Old 11-06-2009, 04:37 PM
Vehicle: 2005 Ford F150
Edge lists 2632mm for 33s, but I would reduce that by 3% for squish. So I would enter 2553.
Flowmaster 40, K&N dropin, Tint, Roush wheels, 305/50/20s
Edge Evo with PHP custom tunes, GF 2" shackles
Old 11-06-2009, 04:46 PM
Thanks Bluejay! Any idea if i should be changing my gear ratio? Or where i might look to see what i have?
Old 11-06-2009, 04:51 PM
Quote:
Assuming your gears have never been changed, check the tag on your drivers door, for the Axle Code.
Compare to this list:
F-150:
19 – 3.55 Non-LS
18 – 3.08 Non-LS
H9 – 3.55 LS
B6 – 3.73 LS
Then, when you go to custom settings, see what the default is in the unit. If not what your axle code says, then change it.
Old 11-06-2009, 04:54 PM
No, unless it's wrong to begin with you don't want to change your gear ratio unless you've actually swapped out your gears.
- NCSU
Photo Galleries: http://www.f150online.com/galleries/....cfm?gnum=7659
Old 11-06-2009, 05:09 PM
Quote:
- NCSU
My Edge always defaults to the wrong ratio, so it's good to make sure.
Old 11-06-2009, 05:18 PM
Does that happen even if you have one of the tunes loaded up?
- NCSU
Old 11-06-2009, 05:23 PM
- NCSU
Not sure what you are asking. Been a long time ago, but I am pretty sure if I was in Level 2 and did not save the settings, if I switched to Level 3, I had to change my tires and my gears, along with the shift pressures, etc. When I got the custom tunes, I asked Bill to set them on 3.55s and he forgot to do it in one of them, so it still defaults to 3.73 and I have to change it. It may have to do with my Edge being an early model and I never downloaded any upgrades to it.
Old 11-06-2009, 05:30 PM
Gotcha, I'm using the Xcal2 and with the custom tunes everything is already set up for my truck. Wasn't sure how the canned tunes work in that regard.
- NCSU
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
