F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Wheels, Tires & Brakes
Wheels, Tires & Brakes Click Here
Thread Tools Display Modes
Old 11-03-2009, 04:26 PM
Tire Sizes and MPG?
OK, so first off I bought a truck, yes I get it. I shouldn't be so picky. But I have to ask.
The stock truck comes with 17" tires. I am considering getting a set of winter tires on the stock rims, and then maybe moving up to a set of 18" or 20" rims for the summer. I am not looking to get knobby offroad tires (it's a 4x2, so why?), but a nice set of 3 season street tires.
My question is if moving up to a bigger set of rims will make an impact in the MPGs the truck gets? Or, as the ladies say, size doesn't matter?
Ignorant minds want to know.
Old 11-03-2009, 05:13 PM
Vehicle: 2002 Ford F-150
Well, you have to take in consideration of the total diameter of your tires\rims. Increasing those in anyway (larger rims or larger tires) is definitely going to decrease mpg's. For example, I have a 285\70\17 tire on my stock 17" wheels which is basically 33" diameter. If I were to put on a 16" rim and run 285\75\16 tires(also basically 33"), I'm not really changing the over all diameter of my wheels so my mpg shouldn't change that much if at all. If you do change your diameter by a good amount, your speedometer will be off and you will actually be traveling more miles then your odometer is reading thus making any gas mileage calculations incorrect\bad.
02' F-150 XLT Sport | 4.2L | 4x2
6" RCD lift | 4.56LS | RCD rear traction bars
Troyer Tuned XCAL2 | AF1 intake
285/70/17 BFG AT KO's
Old 11-03-2009, 07:56 PM
Vehicle: 2008 Ford F150 4x4
If the overall weight of the wheel increases then your MPGs will decrease.
If the outside diameter of the wheel increases then your MPGs will decrease.
When you get bigger tires, both will increase at the same time.
08 SuperCrew Lariat 4x4, Redfire / Arizona beige, e85, 5.4, 373 LS, Leather heated capt chairs, tow package, chrome step bars, moon roof, power rear slider, bed extender, 6 disk CD, Audiophile, Sirius, reverse camera, 20" aluminum wheels,
Bedrug, Undercover, Herculiner, Garmin 265WT, Bluetooth, Edge Evolution, PIAA silicone wiper blades, Bilstein shocks.
Wanted: Navigation radio.
Old 11-03-2009, 09:34 PM
Vehicle: 2005 Ford F150
Send a message via AIM to 05BlackFX4
as long as your ratio stays close to your stock tires/wheels you will get close to the same MPG's..
The bigger the wheel you get the smaller the sidewall of a tire you will need in order to stay close to stock MPG...go too small though and you will find yourself blowing out tires and bending wheels when you hit bumps in the road.
'02 Roush Replica/'05 F150 FX4
Old 11-05-2009, 01:40 AM
Vehicle: 2006 Ford F150
on my 06 ive dropped around 2-3 mpg.
exact same size tires as stock 275 65 18 but I went with a all terrian tire that are softer then the stock rugged crapolas that came with it. however I expect my mpg to improve when it goes below freezing so the compound hardens up a bit
Old 11-05-2009, 10:14 PM
Vehicle: 2005 FORD F 150
Hey snopro31 , Did you reprogram speeo when you changed tires. if you did not then milage is not off as much as you think.
Old 11-06-2009, 01:43 AM
Quote:
I stayed with the same size. shouldnt have mattered.
Just a different tire.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
