F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Wheels, Tires & Brakes
Wheels, Tires & Brakes Click Here
Thread Tools Display Modes
Old 11-02-2009, 10:22 PM
wheels for 01 expedition 4x4
im looking to get new wheels with my lift i want to run 315/75 16s
now my question is what offset and back spacing should i b looking for so they dont stick out of fender well more than a inch
Old 11-02-2009, 11:07 PM
Vehicle: 2001 ford f150
That's not really an issue with the 01's. I have 16x10's with 4.5 inches of bs and my 315's are just about even with the edge of my front fender flares.
How much lift do you have?
2001 GEN III Supercrew, 4x4, gry interior, power bench seat with lumbar support
MODS...3" Body Lift, 315/75-16 BFG AT KO's on 16x10 Eagle 102 rims, Access roll up tonneau cover, tinted windows, chrome Westin nerf bars, SVT Lightning taillights, Pro Comp ES3000 shocks, Superchips tuner, Pioneer speakers
2005 Expedition, white Eddie Bauer Edition. MODS: 305/45-22 Falkens on chrome 22x9.5 Eagle Alloy 026 wheels, 20% window tint
Old 11-02-2009, 11:14 PM
ok thanks what about the offset im looking at **** cepk dc1 and they have a -12 offset and i just purchased a performance accesories 3 inch bl even though local shop keeps trying to sell me a key leveleing kit for 350 installed
Old 11-02-2009, 11:16 PM
I'd run from any shop recommending aftermarket torsion bar adjustment keys. I'd go with a 10 inch wide wheel with 4.5 inches of backspacing like mine.
Old 11-02-2009, 11:22 PM
ok cool so the offset is not as critical then? have oy had any treanny problems speedo problems with the 315s and what of the following would you choose
Wheel/Tire Size: 16"
Width: 10"
Lug Pattern: 5x135mm
Offset: -25 mm
Back Spacing: 4.52"
Finish: Polished
Material: Aluminum
Max Load: 2500lbs
Width: 8"
Offset: -12 mm
Back Spacing: 4.03"
Finish: Polished
Material: Aluminum
Max Load: 2500lbs
Color: Black
Old 11-02-2009, 11:53 PM
Vehicle: 1999 Ford F150
Wandell I have been wanting to put 315's on my 99 as well I already have a 3 inch body lift, from your sig it looks like thats all you have as well I have 16 x10 inch wheels already. I have been recommended to look into a leveling kit with new keys and rear blocks.
from your experience what would you recommend?
Old 11-03-2009, 01:12 PM
The aftermarkt torsion bar adjustment keys have to be the worst product ever made. They allow you to put way, way too much preload on your torsion bars which will destroy your ride quality and cause increased wear and tear on your front end. Just crank up the preload enough to level the truck using the OEM adjustment keys. Why on earth people spend money on a product that allows them to do something that can be done for free is beyond me.
Slayer, as I said, I'd go with the 10 inch wide wheel with 4.5 inches of BS. BS and offset are just two different ways of measuring the same thing. BS is just much easier to understand because it doesn't change with the width of the wheel.
Old 11-03-2009, 11:00 PM
Vehicle: 1999 Ford Expedition
Wandell speaks the truth about the torsion keys...though I have never used them, I have never heard good things about them. I simply turned mine and added 2" coil spacers. Running 305,s on a 16x10.
A few of my past Expeditions. 3" PA body kift, turned torsion bars with 315,s on 16x10,s
http://fordtruckworld.tenmagazines.c...y.asp?id=19285
Boyz In Blue Have Fun Too
99 LIFTED Eddie Bauer/04 Eddie Bauer
Same set up, prior to Bushwacker fender flares
Old 11-04-2009, 07:35 PM
sweet truck man can anyone explain how and what tools are needed to turn the stock keys
Old 11-04-2009, 10:41 PM
I used an air wrench with a socket. Just measure, and measure well. I went from the middle of each wheel opening, straight down in front of the center cap. Its sounds alot tougher than it is, just have to do it a couple of times. Unfortunately, Ive done it 4 times on 4 different expys. Replied to your message
Old 11-04-2009, 11:16 PM
RIght, all you have to have is an 18mm wrench. It's easier if you jack the front end off the ground.
Old 11-20-2009, 12:36 AM
Thanks for all the advice guys, I fit the 35's on under the body lift with minimal trimming and only a small adjustment to the Torsion bars. looks great
Old 11-20-2009, 10:07 AM
Sweet. You need to get us some pics.
Old 11-20-2009, 03:16 PM
Definitely need pics
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
