F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Wheels, Tires & Brakes
Wheels, Tires & Brakes Click Here
Thread Tools Display Modes
Old 10-19-2009, 11:46 PM
Vehicle: 2008 Ford F150
air presure sensor
if i get new rims and tires, can i still use the air preasure sensors that r in my stock tires now?????
08 f150, 4x4, stonegreen, westin bumper, 2.5" leveling kit, tint, fire and ice lightbar, backup lights,
Old 10-20-2009, 07:41 AM
Vehicle: 2006 Ford F-150
I think the sensor is tied in with your valve stem, so I would say no.
Old 10-20-2009, 08:25 AM
Vehicle: 2009 Ford F150
Yes you can, but you will need new straps to hold the sensors on to the wheel. Even if you have the valve stem type, which I believe the started only on the 09, you can purchase valve stems that the sensor screws on to.
Old 10-20-2009, 01:00 PM
so if my 08 had the strap around the wheel then i couldent just take it off and put on another rime that is the same size but wider?? my rims i have now 4 18 and im looking into a 18x9 or a 20x10 so what would it cost me to get the sensors on both of these rims or can i just use the ones i got for the 18x9???
Old 10-20-2009, 01:05 PM
Vehicle: 2002 FORD F150
yea you can put your factory sensor in a aftermarket wheel, ford wheels have what they call "band sensors", its pretty much a giant hose clamp with a sensor that slides on it, i work at discount tire and plenty of these come through
2002 F150 FX4
Old 10-20-2009, 01:12 PM
Vehicle: 2001 ford f150
The OEM bands are not reusable are they?
2001 GEN III Supercrew, 4x4, gry interior, power bench seat with lumbar support
MODS...3" Body Lift, 315/75-16 BFG AT KO's on 16x10 Eagle 102 rims, Access roll up tonneau cover, tinted windows, chrome Westin nerf bars, SVT Lightning taillights, Pro Comp ES3000 shocks, Superchips tuner, Pioneer speakers
2005 Expedition, white Eddie Bauer Edition. MODS: 305/45-22 Falkens on chrome 22x9.5 Eagle Alloy 026 wheels, 20% window tint
Old 10-20-2009, 01:14 PM
Quote:
so would the one on my 18" rim work on a 20x10 or just the 18x9
Old 10-20-2009, 02:02 PM
You will have to replace the bands, since they are not reusable. Very expensive from Ford, so your best bet is aftermarket. What you will have to transfer is the sensor and the cradle that holds it.
Old 10-20-2009, 02:10 PM
Quote:
how much is it??
if there that expensive then im not going to worry about it and if that is the case then how do u disconnect the light on the dash to keep it from stayin on cause if u dont have it connected i would thing the dash light would stay on???
Old 10-20-2009, 02:34 PM
Not sure what the aftermarket bands cost, but the Ford bands are about $40-$50 each. I believe you can get all 4 aftermarket for the price of one from Ford. Do a search, as I believe some have listed the price they paid for the aftermarkets.
As far as disconnecting, you would probably have to rip the dash apart to do that, assuming you can get to it. More than likely, as the dash is one piece, you will not be able to do that.
Old 10-20-2009, 02:42 PM
oh ok thanks ill search and see what i come up with
Old 10-20-2009, 10:44 PM
Or you could save yourself the $$$ and headache and just drive around with a little tiny light on in the corner of the dash that you can barely see. If you adjust your steering wheel slightly you can actually block the light from your view. Thats what I do, a spec of light on the dash doesn't bother me unless its a check engine light. At least not enough to go ripping apart a dashboard!
Old 10-21-2009, 12:03 AM
Quote:
yea u have a very good point there, ill still look into the aftermarket sensors just to see,
Old 10-21-2009, 08:27 AM
You do not need aftermarket sensors, just the straps that hold them on to the wheel. Probably the cheapest component to replace. Only other cost will be to break down the OE tires to get the sensors.
Old 10-21-2009, 11:15 AM
what does the sensor look like, r there any pic
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
