F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Wheels, Tires & Brakes
Wheels, Tires & Brakes Click Here
Thread Tools Display Modes
Old 10-16-2009, 05:05 PM
Vehicle: 2010 Ford F150 4.6L
Quote:
Originally Posted by mitchy View Post
I ended up going with the Wrangler Silent Armors this afternoon. Now I got nothing like the $572 deal - that's an awesome price. Mine will be about $820 after the rebate.
I found the lowest price at the local Ford dealership (of all places).
What size did you end up with?
Old 10-16-2009, 05:12 PM
Vehicle: 2001 Ford F150
I also got mine from the Ford dealer. I got P265/70R17. Really thought about the LT's, but decided to go with the P's. So far I'm pretty happy with them. Gonna put the camper away for winter soon here, so I'll get to try them out towing then.
2001 F150 SuperCrew XLT
Old 10-16-2009, 06:12 PM
Vehicle: 2009 Ford F150
What is the max pressure on the tires, and what are you running them at.
Old 10-16-2009, 06:51 PM
That explains the price difference. Mine are the 255/75/R17's.
Old 10-16-2009, 08:47 PM
Max pressure is 44psi, but they only inflated them up to around 30. I think I'll run them a little higher when I tow, but will probably run them at 30 the rest of the time. They don't bulge much at all when I'm empty at 30psi.
Old 10-16-2009, 09:17 PM
30 is way too low. You are losing 25% or more of the weight carrying ability at that pressure. You should be closer to 38 non-towing and near max when towing.
Old 10-16-2009, 09:31 PM
Kingfish51, do you see that 38 in a manual somewhere, or are you just basing that off the max pressure of 44? I looked on Goodyear's site, but couldn't find any sort of manual. Why would they inflate them so low at the dealership?
Old 10-17-2009, 02:29 AM
I double checked and I misstated earlier - the dealer inflated it to 35 psi, not 30. So it's closer to the 38 you mentioned. I would be interested in seeing any reference you might have though. Thanks
Old 10-17-2009, 08:30 AM
Mostly from experience and looking at things like what the manufacturer recommends for different tires with different load ratings. As vehicle weights have gone up, the recommended pressures for the same LR have gone up. An example would be the 2001, 2004, and 2009 trucks I have had. All came with LR C tires with about the same weight capacity. The recommended for the 01 was 38, for the 04 it was 40, and now for the 09, it is 45. My 07 came with P series with a max of 35, recommended was 35 as the p series was right at the limit. You are closer to the limit with your P series than you would be with a LR C, so your pressures need to be closer to the max.
It is always better to run a little high, than run low, as too low a pressure will cause the tire to have excessive tread wear and build heat at highway speeds, which can cause blowouts and tread separation. Too high in general will only cause higher trade wear as long as pressures are within the tires limits.
For more info on pressures, see this site and others like it. http://www.tirerack.com/tires/tirete...e.jsp?techid=1
Old 10-25-2009, 02:25 AM
Vehicle: 2006 Ford F150
I put 275 65 18's on in september. have around 5 thousand miles on them and they are great tires. I got the P rating due to the fact I have never had a blow out on any tires I have ever had and I don't tow a heavy trailer. Ive used these tires all over in all conditions (snow, ice, mud, clay, gravel, dry/wet pavement) and they are awesome. Actually, they seem better then the bfg a/t's.
I too was wondering about going P or Lt but went P. The price was somewhat a factor as my bill was 1126 OTD all included for 3 tires (got one free).
Old 11-12-2009, 01:54 AM
I've been running my 255/75/R17's (Silent Armor Wranglers) at 39 psi with good results on pavement. I left the pressure there when I drove about 30 miles through mountain snow from 1" to 4" deep and they were impressive, especially considering they are not a dedicated snow tire. The relatively narrow width allowed them to cut through the sloppy stuff while retaining good directional control and the tread pattern provided excellent traction even in the sloppiest transition zone (of course they have full tread still).
I also did about 30 miles of dirt road which was mostly slick, wet clay and they gripped really well. When I purposefully broke them free on some of the more slippery sections they hooked up faster than expected.
All in all, I'm suitably impressed. I still can't believe they were less than $600 installed. Normally I don't buy cheap tires.
2010 F-150 Supercab 4x4 145" WB
4.6L 3V w/ 6 speed
3.73 LSD
Reg. trailer tow package
7000# GVWR package
Old 11-12-2009, 02:20 AM
Those silent armours do have the snow flake rating applied to them.
Old 11-13-2009, 12:08 AM
Vehicle: 2000 Ford F-150
I've had my set since fall 06, love em. My only bitch is they don't come in 305/70/17, would of like to try that size next. If I can make a suggestion, get the LT IN 285/70/17 IF YOU HAVE 4X4. I think it's a good size, and makes the speedo dead nuts accurate too with gps as reference. They are great tires for the all season driver, never really off roaded with them, sure they do fine too. Pics in gallery.
2000 F-150 XLT 4X4 Regular cab Flareside
5.4L Windsor 4R70W Auto
3.55 L/S
285/70/17 Goodyear Silent Armor tires
http://www.f150online.com/galleries/....cfm?gnum=7529
Old 11-16-2009, 03:04 PM
Quote:
That's true but when I said they were not a "dedicated" snow tire I was speaking to their rubber compound. A dedicated snow tire needs to be removed as the weather warms or they will wear out pronto. But dedicated winter tires are the only way to go if you want the best possible winter traction (and the difference is huge, especially in icy conditions). Modern winter rubber compounds have almost made studs obsolete.
Old 11-16-2009, 04:02 PM
Oooops!
Oooops.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
