F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Wheels, Tires & Brakes
Wheels, Tires & Brakes Click Here
Thread Tools Display Modes
Old 10-10-2009, 08:22 AM
Vehicle: 2004 Ford F150
replacing brake fluid- "gravity method"
This may come across as a silly question, but do you HAVE to pressure-bleed brakes to change the fluid?
Or; Can you attach a short length of tubing to the bleeder, to drain into a can, open the bleeder, then open the master cyl. and just refill as gravity drains it.
Then just close the bleeder when you see the new clean fluid coming out?
Then move on to the next wheel.
Would this method work?
All input is appreciated
Old 10-10-2009, 09:10 AM
Vehicle: 2005 Ford F150
From all my experience, and that ain't much, it takes 2 people to do a brake line bleed. One to open bleeder and 1 to apply brake slowly and firmly while the bleeder is open. Also make dam sure the reservoir stays full, u get air in those lines and oh boy.
Old 10-12-2009, 12:54 PM
Send a message via AIM to mkosu04
its theoretically possible, but would take quite a while.
you'd be better off buying one of the low-price vacuum bleeders that lets you suck the fluid at the caliper.
Also - before you start, use a turkey baster to remove the fluid from the reservoir and put new in... it will save you time.
- Matthew
2004 FX4 SuperCab w/ 6.5' Bed - Dark Shadow Grey
K&N Filter, Edge Evolution, Corsa Sport Exhaust, Herculiner
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
