Calculating Tire Size
Old 01-05-2011, 04:26 PM
shotgunz's Avatar
2610 is the unloaded (i.e. perfectly round) circumference.
Tires are not perfectly round. When loaded, they squish (anywhere from 2-5%). This reduces the effective diameter.
Thus you need to reduce the unloaded diameter by multiplying the unloaded diameter by .98, .97, or .96, etc. as a starting point. Then you need to confirm/verify with a known speed (i.e., GPS) or distance (Google maps) and adjust based on the percentage of your error.
Old 01-06-2011, 11:21 AM
ridinonmoto17s's Avatar
i did the .97 squish and my gauges show about 2 mph higher than my programmer. should i go more squish or less squish. lol
Old 01-06-2011, 11:36 AM
The truck speedometer will always be about 2 mph faster than the digital readout. Ford builds them that way. Get you digital readout calibrated to a GPS to make sure you have it correct.
Old 01-06-2011, 11:47 AM
ok. but if i leave it the way it is now should i go by my gauges or the programmer. its an edge evolution.
Old 01-06-2011, 11:57 AM
Yes, but how do you know it's dead on? The digital could still be off.
Old 01-06-2011, 12:02 PM
lol i'll just have the cop in my town use his radar to check it. i can get by with warnings by saying the tires have my gauges off, the cop just says have it flashed and heres your free pass be glad im in a good mood. lol works about 95% of the time. and we took my gf's g6 on a trip and took the garmin and the garmin always read 3-4 mph lower than her gauges and its bone stock with the same tires it came with from the factory. so maybe i shouldnt rely on my gps
Old 01-06-2011, 12:13 PM
I would bet the gps is correct and the car speedo is off. I would set the Edge to match the Garmin, then ask the cop to check it for you.
Old 01-27-2011, 05:10 AM
Bothom's Avatar
hi shotgunz,
thanks for providing the tire size calculator. i will really help many users at this forum.
you did really a good job.
9xm live tv
Old 01-28-2011, 04:49 PM
jerrybizzle's Avatar
Here is imo the best tire size calculator I have found. Let's u put in stock size and compare up to 3 prospective sizes. Check it out.
www.1010tires.com
Old 01-28-2011, 05:00 PM
Old 02-11-2011, 05:12 AM
gilsnuxs's Avatar
Can someone tell me what nimber they are using for 295/70/18 Trail Grapps. I had my truck broken into and my GPS unit stolen. My cell phone has a GPS unit, but it doesnt have and odometer.
Old 02-11-2011, 05:43 AM
shotgunz's Avatar
Should be between 2597 (5% squish) and 2652 (3% squish).
You can also use Google Maps for accurate distances...
Old 02-14-2011, 09:58 AM
mdhawkin's Avatar
I am running 2651 at 45psi.
Old 02-18-2011, 10:32 AM
mattp868's Avatar
ok i have a question. i have stock 20" rims on my f150. current tires i have right now are 275/55/20. i want to go bigger. would i be able to put a 35x12.5x20 tire on these rims?
Old 02-18-2011, 11:04 AM
Your question would best be asked in a new thread in the Wheel and Tire forum.. It is a little off subject in this thread, plus may not be seen by many.
Quick Reply: Calculating Tire Size
