F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Wheels, Tires & Brakes
Wheels, Tires & Brakes Click Here
Thread Tools Display Modes
Old 11-22-2008, 04:00 PM
Vehicle: 2007 Ford F-150
Paint your OEM wheels: Step by step w/pics (56k warning)
First off props to zeruin for giving me the quick run-down on how to do this. I'm by no means an expert, but I thought I would share how I painted my wheels in case anyone else wanted to do the same. It is a good way to save some money and completely change the look of your truck. I'll post the way I did mine, although some of the steps are optional.
First you'll need your material:
-Duplicolor wheel paint
-Duplicolor clear coat
-Self-etching primer
-Spray can gun
-Degreaser
-Towel
-Brillo pads
-Spray bottle
-400 grit sandpaper
-Sanding block
-Masking tape
-Index cards
-Newspaper
The first thing I did was wipe down the wheels with some simple green to clean them up.
Then I used some brillo pads to scuff them up a bit and to completely remove all traces of dirt and grime. I kept my wheels really clean so this wasn't too bad, although it may be harder if your wheels are coated in crap.
After brillo pads:
Then take a sanding block and sandpaper and go to town. This was the most tedious step, as you want to make sure to scuff everything up so you have a good bonding surface for the paint. I ripped up some small pieces of sandpaper to get in the smaller grooves. Then use some more degreaser and make sure everything is cleaned up nicely.
Now mask off your wheels. I used some index cards between the wheel and tire and then masked off the surrounding tire with newspaper. I also stuffed some newspaper between the spokes to avoid painting the rotors. Now use some self-etching primer. I put on two light coats with about ten minutes between coats. Working around the truck with all four tires gives enough time so you shouldn't have to wait any--just keep moving. I was diggin' the army green color, although my neighbors were looking at me like I was crazy.
After letting the primer dry for 30 minutes or so it's time to paint. Grab some of the wheel paint and do light coats. This is always my problem as I like to lay on coats heavier to make sure it's covered evenly. Trust me, light coats and you'll be fine. The first and even second coats may not cover all parts of the wheel, but after a few more light coats it will look great. Same as with the primer, if you're working around all four wheels you shouldn't have to wait between coats.
After first coat (I still think I went too heavy here):
After five coats:
I let the paint dry for 45 minutes and started the clear coat. I did four light coats using the same light coat principle. You can vary this based on how glossy you want your wheels to be. Looking back I wish I'd have done less clear and gone with a more matte finish since my tires are so faded.
After first coat:
After four coats:
Now just let it dry overnight and you'll be set. After the first hour of drying I suggest removing all newspaper and index cards. If you leave them on and let it dry completely there is a chance it will try and tear off some of the paint when you remove it.
Letting it dry:
Newspaper removed:
Hopefully this helps if anyone wants to or has been thinking about painting their wheels. It was a very simple process and I'm very happy with the results.
Finished product:
Now I just need some new tires!
Old 11-22-2008, 04:07 PM
Vehicle: Fort Lauderdale
Very nice writeup..............Maybe sticky material?
http://www.screen-fx.net/
Old 11-22-2008, 04:43 PM
Vehicle: 2004 ford f150
looks really good!!
[IMG][/IMG]Exterior=22" ROOK WHEELS FALKEN 305/40-- All led exterior lights--patriot decals--2" drop shackles,roush grill--Performance= 14"magnaflow with lightining exhaust--k&n drop in filter.
Old 11-22-2008, 04:59 PM
Vehicle: 2001 Ford F150
Send a message via AIM to coobies5
awesome job
looks great!
2/4 4x4 4.6 xlt, 5k 55w ddm, slp lm1, nathan k3la, sundown saz3000d amp/pioneer deh-p5100ub/18" fi btl fully loaded, vmp tuned, k&n cai
Old 11-22-2008, 05:11 PM
Vehicle: 2005 Ford F-150
Great write up, looks great. Sticky?
Mods: 2005 Lariat 2wd
6" Fabtech
Fabtech Steering Stabilizers
Line-X
35x12.50 18 Toyo M/t's
18" Rockstars
Access Roll up cover
K&N Drop in air filter
Soon to come:
09 Badges
Patriot decal Ovals
Gas
Old 11-22-2008, 05:53 PM
Look good BUT you should of take off the balancing weight.
When you're going to change your tire, you're going to have a sweet little ''stock paint'' spot on your rims.
Old 11-22-2008, 07:20 PM
Thanks guys! Hopefully this helps someone.
I thought about that but I'm getting new tires and wheels in January. My purpose in doing this was to see if I'd like my truck blacked out or not.
That's a great point, though, for someone looking to do this permanently. From what I've read it's nothing a little touch-up paint can't fix, but it would be a good idea to take them off first. Also I might add that they've been painted for over a month now and show absolutely no signs of chipping! I've taken them through the self-wash several times and the pressure washer has no effect. Also have scrubbed them with a hand wash pretty vigorously and they're fine. I think this would be a great solution for someone if they want their oem wheels a different color.
Oh and by the way Pat, nice post count
Old 11-22-2008, 10:38 PM
Vehicle: 2001 ford f150
Nice job.
2001 GEN III Supercrew, 4x4, gry interior, power bench seat with lumbar support
MODS...3" Body Lift, 315/75-16 BFG AT KO's on 16x10 Eagle 102 rims, Access roll up tonneau cover, tinted windows, chrome Westin nerf bars, SVT Lightning taillights, Pro Comp ES3000 shocks, Superchips tuner, Pioneer speakers
2005 Expedition, white Eddie Bauer Edition. MODS: 305/45-22 Falkens on chrome 22x9.5 Eagle Alloy 026 wheels, 20% window tint
Old 11-22-2008, 10:50 PM
Vehicle: 2002 ford f150
ive noticed something interesting... (btw, great post) in your pictures, specifically in these: newspaper removed- i can clearly see your FX4 decal. as i scroll down to the next pictures, i cant see it! is this an illusion from the light, or what?? i only ask because i notice this kind of thing. i dont know why....
Old 11-23-2008, 12:10 AM
Vehicle: 2008 Ford F150
Quote:
From them looks of it, he actually took them off. From what I know, he plans on picking up some new decals from patriotdecals.com. You can see he had painted his Ford ovals. Check the pic when the orange bag on his hood, the oval still says Ford, then the last pic, it's painted black.
anywho.. Good job mblouir, I think it turned out pretty good. When ya get the new wheels/tires are you gonna lift it up or..? I think the tires would look fine if ya keep some tire dressing on them.
2008 Blackout FX4 - 6" Procomp, 35" Toyo MT, 20" Procomp 7005 wheels, 4.56 Yukon gears, True-dual Magnaflow exhaust, AF1 3.0" intake, VMPtuning X3, and a lot of black spray paint.
-Exhaust clip- http://s340.photobucket.com/albums/o...nt=exhaust.flv
Old 11-23-2008, 12:20 AM
Vehicle: 2007 ford F150
ive been thinking about this, any chance it could be done with the chrome oem wheels I have?
2007 F150 XL 4.2L V6
Flowmaster 44 Dual Dumped exhaust
Line-x Bed liner
AS 2.5 Leveling kit
17x9 Eagle Alloy 102s Painted Black
33in Mickey Thompson Baja Claws
Old 11-23-2008, 01:50 AM
Zeruin nailed it on the head--I took them off. Already got the overlays and I'm planning on picking up some new decals like he said. Not planning on lifting it until I get out of college. Once the money supply increases it's fair game. And yeah I try my best to keep dressing on them but it wears off fast. My apartment complex cuts the grass (dirt) early in the week and my university campus cuts theirs later in the week. So it's a constant battle to keep them shiny.
Quote:
I'm sure it would be fine as long as you sanded down the wheels enough. I'd even suggest trying a wire cup brush. That should help the sanding process tremendously. Then after using the wire cup brush sand it down with paper. Every red truck I've seen with black wheels looks really mean, I say go for it!
Old 11-24-2008, 09:43 PM
Vehicle: 2001 Ford Ranger
Send a message via AIM to ModBargains
Nice writeup! Looks good.
Old 11-24-2008, 11:34 PM
Thanks! Another set of before/after pics. It really makes a huge difference.
Old 11-24-2008, 11:44 PM
nice nice.. did you ever finish painting your flares or steps?
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
