Emergency Brake and Tightening It
Old 07-04-2007, 09:18 PM
150Lariat2000's Avatar
Today I went out and put new rotors on my rear end of my 2000 F-150.... Everything went great but can you guys tell me how to tighten up my emergency brake?? It does not lock up all the way and I want to put a little more pressure on it. Thanks....
Old 07-06-2007, 11:52 PM
Bump!!!!
Old 07-08-2007, 12:27 AM
Steve83's Avatar
Look at the diagram at the end of this album. You have to remove the rotor to get to the adjuster.
Old 07-08-2007, 10:58 AM
Thanks Steve for your help.... Guess I will be redoing the brakes again.....
Old 07-08-2007, 10:05 PM
Quick question.... How tight should the emergency brake be??????? I can put my truck in drive with emergency brake on and it goes no where, if I hit the gas it will.... Is that tight enough???
Old 07-09-2007, 07:27 PM
Steve83's Avatar
Are you asking how hard to press the pedal? Press it until the brake holds. If it gets to the floor & won't hold, it's not tight enough.
Old 07-13-2007, 01:16 PM
mkosu04's Avatar
For future reference - the adjuster will adjust automatically. If you would have done a series of brake applies it would eventually tighten up. It only turns just so much per apply. The mechanism is designed this way to account for pad wear.
I can't go into detail on the design in your truck, as I don't know who was making them for that model. But I'm fairly certain that it has a similar design as the current production.
So, as far as how far to tighten - get it close and then the mechanism should adjust on its own to keep things tight.
Old 07-13-2007, 01:19 PM
mkosu04's Avatar
Arrow Video demonstration of Automatic Adjustment
aha... I've found a simple little demonstration of how the generally work...
http://static.howstuffworks.com/flash/drum-brake2.swf
Old 07-14-2007, 01:05 PM
Steve83's Avatar
No, Ford drum-in-hat e-brakes ('97-up w/rear disk) don't autoadjust. That demo is of pure drum brakes w/e-brake. Drum-in-hats must be manually adjusted by removing the rotor, as shown here.
Quick Reply: Emergency Brake and Tightening It
