Quote:
Originally Posted by chaosbringer79
i have a 2001 f150 supercrew, gonna get 22" rims, do u think i need it?
It all depends on how tall of a tire sidewall you go with. For example:
If your stock tire size is 255/70/16 then you can go with a 295/35/22 tire as they are the same outside diameter.
If your stock tire size is 265/70/17 then you can go with a 305/40/22 tire as they are the same outside diameter.
Only thing that you will need to watch for is the wider tires so you need to watch your backspacing on the rims so that you will not rub when turning.
http://www.miata.net/garage/tirecalc.html
