Viberation during turning
I have a 2000 F-150 Lariat automatic 2WD.
I have LT265/70R17 on my truck.
Ok heres the deal, (from a stop) when I go and turn the wheel at arround 5mph. I feel a vib for a short amount of time both left and right turns. This vib only happens during a small part of the turn as if there is a small bad spot during the range going left or right.
I don't feel it turning at a faster speed but then I wouldn't turn at arround 50mph.
If I was to guess at what degree this happens (if straight is 0 degrees, then it happens arround 30 to 40 degrees and again for just a fraction of a second).
I did buy the truck used and it looks like the previous owner did rub against several sidewalks so I'm guessing that the tires are bad but I want to hear from someone from this forum that has more experience.
Thank you
Thank you
