Backspacing same as Offset?
No. Backspacing is the distance from the wheel mounting surface of the wheel to the innermost aspect of the wheel, whereas offset is the distance in mm from the center of the rim (ie 4.5" on a 18x9" rim) to the wheel mounting surface. The two are related, but not the same.
https://www.rsracing.com/tech-wheel.html
Has a pretty good explanation with pics/diagrams. A good read.
Originally Posted by Bryndon
How wide is the wheel? Basically, take the width of the wheel and divide by 2. Then add your offset. That's your backspacing.
Originally Posted by wandell
No, the OEM 17 and 18 inch wheels on the 04-07's are 7.5 inches wide and they have 5.5 inches of backspacing.
Originally Posted by Mastacator
I know the backspacing....How do you find the offset then?
I'm with Wandell, backspacing is easier to make sense of and is necessary for selecting the right wheels - if the stock wheel is 5.5" backspacing, you really want to stay in that area... more backspacing and you start hitting the frame when turning, less and the stress on the bearings and ball joints goes up. 4.5 - 6 is probably a good range to stay in.
Offset tells you where in relation to the centerline of the wheel the hub face falls - but then you need to know wheel width and calculate to get the rest done. With backspacing, there's less numbers to play with... a 10" wheel with 5.5" of backspacing puts 4.5" in front of the hub. Simple!
