Recalibrate speedo
Old 01-29-2007, 09:55 PM
techniqueauto's Avatar
Recalibrate speedo
I just put 285/75/16 on my f150. Does anyone know how to recalibrate speedo?
Old 01-29-2007, 10:43 PM
BLUE20004X4's Avatar
I bought the recalibrator from Ford Motorsport off of ebay, 100 bucks. I dunno if I'm going to get around to installing (procrastinator) but from 265 to 285 didn't seem to affect my km/h's too much, maybe 3-4 doing between 70-75 km/h. I probably will when the weather gets nicer, kinda limited to work space right now.
Old 01-29-2007, 11:19 PM
ScrewedUPF150's Avatar
Go See the Dealer
Dealer can do it for like 50 bucks I have heard. Ask them before hand what size they can adjust for. If tires are too big then they can not.
Old 01-30-2007, 12:59 AM
GrnXnham's Avatar
Do a search here. You'll find a ton of info on this. Since you have a 98, you can probably just change out the speedo gear in the tranny. The gear is only about $10 and you can swap it out yourself.
It's so easy, a caveman could do it.
Old 01-30-2007, 09:13 AM
Bryndon's Avatar
If your plans include getting a programmer, they all allow you to dial in for tire size.
Old 01-30-2007, 09:22 AM
wandell's Avatar
He has a 98. The 97 and 98's are not computer controlled(speedo). You have to recalibrate by changing a small gear on the tranny. A programmer will not allow him to recalibrate his speedo like it will on 99-07's.
Old 01-30-2007, 10:46 AM
MitchF150's Avatar
I put in a 19 tooth VSS gear to recal for my 265/75/16 tires. Stock was a 20 tooth. You need to 'speed up' your speedo/odo, so a smaller gear turns more rpms. You will probably need an 18 tooth gear to do the same thing assuming you have 3.55 gears.
Mitch
Quick Reply: Recalibrate speedo
