Spare Tire different size....
if you have the Limited Slip rear diff. and you happened to be so lucky as to flat a rear tire, on a longer trip home, it may be beneficial to pull one of the 33's from the front and mount that in the rear to keep the LS happy (other wise the clutches may see the size difference as a traction loss and attempt to correct)- and put the smaller spare up front- obviously this will produce a bit of left/right pull due to the size difference- other than that- you should be good to go!
