May sound dumb
May sound dumb
this may sound reaaaly stupid but the rims on my truck are reeeal ratty.. buying tires just thinking how i could spice them up without bustiin the piggy bank... i recently purchased paint spray guns and a sand blaster? is there any special kind of paint made for rims?? thanks alot
Good luck.
Mike
its really easy to do it yourself. i have a friend of mine that used high heat spray paint and it looks just as good as mine. you just take the wheels off the truck.(use some jack stands to hold it up) get a good brush and soap and clean them off really well. you dont want any dirt on them. then get some 200 grit sand paper and sand them down really well. you want to have a rough but even surface. then wash them a second time. next you just tape off the tire around the edges of the wheel and spray on the paint. be sure to get an even coat. and if you do decide to do this, i recomend using high heat paint of some kind, because your wheels get pretty hot. i did mine about 6 months ago and they still look like i did it yesterday. they dont show brake dust anymore either.
i did mine with a flat black to match the trim on my truck. but i did try out a spray on chrome first and it looked pretty tight. i think you can get the stuff at like autozone and if not there then probably lowes or homedepot. although im not sure if they have those in canada. you could try some paint website though.
it all depends on what kind you buy.i had a can of spray on chrome, but it was like 10 years old. suprisingly it still worked, but i didnt use simply because of its age. im sure they have some spray on chrome that wont chip. you just gotta look. im not really sure what kind of selection they have in canada. but im sure you can find something on the net.
