2005 Fx4 f-150 tire question
Hey everyone I was wondering if anybody could help me with an issue i have. I would like to get Nitto Terra Grapplers in a 33" or 35" if it will work with no rubbing. I don't really have the cash right now to buy new wheels and want to use the oem 18" x 7.5" wheels. Does anybody know what sizes i need to be looking at, i don't understand tire sizes too well and want to make sure everything will work out. I don't care if the tires stick out of the wheel wells. The truck has a leveling kit (2.5 inch) as well. Thank you guys in advance, I really appreciate it.
As a general rule, on a 04-007 F-150 4x4 with a leveling kit, you can fit 35x12.50's using the OEM wheels or 33's using aftermarket wheels. If you are going to an aftermarket wheel in the future, I'd go with a 33 inch tire. Since you want Terra Grapplers, I'd suggest going with a 325/60-18 (33x13.00) and later installing them on a set of 18x9 aftermarket wheels because they are a little too wide for the OEM 18x7.5 inch wheels.
Because he only has a leveling kit and he didn't mention adding a suspension or body lift in the future. You will have problems fitting a 35x12.50 with aftermarket wheels and just a leveling kit unless the wheels are almost identical to the OEM's. Remember, wheel width and backspacing are just as important to tire fitment as the amount of lift you have.
weights problem
Originally Posted by 05supercrew
2'' AS with 18x9 Helo Maxx6, TG 325-60-18
