2004 FX4 - Vibration at take off (turning)
What in the heck is the problem?
Before my warranty expires, I want to make sure I know what the problem is, or to be able to explain it to the Ford Dealership.
It only happens when I come to a complete stop and accelerate on a turn. As slow as 1-5 mph I feel this annoying vibration.
At first I thought it was my cheap rear tires not griping correctly but from 1-5 MPH!!
Can anyone help me out on this? What do I tell the service department?
Thanks!!
Thanks!!
Thanks.
I'm taking it in......
I found this:
ORD:
2003-2006 Expedition
2004-2005 Excursion, Explorer Sport Trac
2004-2006 Escape, Explorer, F-150, F-Super Duty, Ranger
LINCOLN:
2003-2006 Navigator
2006 Mark LT
MERCURY:
2004-2006 Mountaineer
2005-2006 Mariner
ISSUE:
Some vehicles may exhibit a tire/wheel vibration caused by excessive runout.
ACTION:
The following procedure should be used if normal diagnostics lead to a potential runout issue. The procedure is intended to assist with the diagnosis of tire/wheel assembly runout and/or force variation issues. To diagnose and correct the concern, refer to the following Service Procedure.
NOTE: FOLLOW THIS TSB PROCEDURE ONLY IF THERE ARE NO SPECIFIC TSBs/SSMs RELEASED FOR THE VEHICLE SYMPTOM BEING EXPERIENCED.
GENERAL INFORMATION
NOTE:
I found this:
ORD:
LINCOLN:
2003-2006 Navigator
2006 Mark LT
MERCURY:
2005-2006 Mariner
ISSUE:
ACTION:
GENERAL INFORMATION
NOTE:
Well , what's happening is your driveshaft isn't slipping on the Yoke spline properly because it's dry and it's binding your clutch pack (Hard turns -one wheel rotates more than the other, if the shaft doesn't slip on the spline as it should - it binds the pack) Theres a TSB on it, But unfortunately , not a recall.
You/they need to pull the shaft and apply some teflon grease to the splines. Have Ford do it if under warranty. Theres a chance the clutch pac is spent now, so haveing them do it - since the TSB exists. There prolly going to replace the pac anyway..Take it in..
There is two separate TSB's rear end and shaft related. This one's named the "clunk" TSB, by Ford Motor.
-Joe
I'm just saying theres two TSB's that exist back here - There should be one because they tie into each other.
One they call Clunk(thats an older one) / The clunk happens at take off low speeds - the spline teflon grease TSB .
Then that (clutch pack) Chatter - On right/ left turns TSB.
That's right, there is one more -Then you have the high speed vibration above 45mph fluid break down/modifier TSB..
Which on do you want to see I have all of them..
-Joe
Hi Joe,
I see your point , I may of been misinforming , I will have to correct if I am.. I believe they work together . There's three different types of setups, I'm learning as I go here so , yes correct me if wrong. - Open, LS, Traction Lock. From what I gather these TSB's apply to all - I'll re-read tonight. All systems float , I got that , but isn't it possible that if the drive-shaft sticks stationary on the spline in a hard turn with the wheels turning different rotation speeds that it would apply enough pressure to shift the clutch pack out of it's tolerance ? I think it's good idea to eliminate that possibility , I posted it so it may save some grief later on .. Worst case scenario I think it's possible..
Yes your right - there's two separate TSB's - Keeping the shaft sliding on the spline as it should is easier on everything..At this point I believe one could effect the other.
[QUOTE=jbrew]Hi Joe,
That's only two. The Ford Trac-Loc rear axle is Ford's proprietary limited slip rear axle, and there are far more than just those two options, but that's another discussion for another thread.
Nope. The TSB for the rear axle doesn't apply to vehicles with an open differential.
I don't understand what you mean by this? What floats?
No. As I already explained, the pinion shaft on the end of the driveshaft is locked in place by a pair of bearings. It does not move fore and aft. Aside from the torque applied to it, nothing that happens to the driveshaft spline affects the inner workings of the differential, limited slip or otherwise.
And I beg to differ. Both problems occur on vehicles independent of each other. Take a truck with a chattering rear diff, yank the driveshaft, and push it around the corner, and it'll still chatter. The clutches still have to slip when cornering to allow one wheel to turn farther than the other.
The spline issue occurs on vehicles with an open differential. It's a single clunk, not a chatter. Read the TSB.
[QUOTE=GIJoeCam]
Hi Joe,
LS ,Traction Lock - one in the same.
The TSB is LS/TractionLock Specific.
Nothing Floats , I misread..
Got It
Got It
So its NOT normal and should be looked at?
Mine is still under warenty but not for long....
What should I say to the dealer?
To ckeck the splines or the Clutch Pack or the simply the fluid?
I always tought it was normal for a limitid slip to react that way under pressure...
I used to run lockers in my Toyotas rear ends so this is pretty smooth compared
Thank you!!!
Thank you!!!
(as a mechanic in manufacturing, I hate when the operator tells me how to fix it... let me see what's broke, then I'll decide how to fix it. That's what they pay me for!)
I used to run lockers in the rear end so this is pretty smooth compared
Thank you!!!
Thank you!!!
