Does it matter if I get Passenger of Light Truck tires?
I have heard both stories. Half say you must get LT tires on a truck. Others say it doesn't matter, P tires are ok. Whats the deal. A P tire is 4 ply and has a lower weight rating than the 10 ply LT tire correct? Do these tires perform differently other than being able to handle more weight?
As long as the tire you are putting on your truck (or any vehicle) supports the load rating of the vehicle, you'll be safe. P-rated tires for most of our F-150's tire sizes are well under axle ratings and GVWR for our trucks.
What's the tradeoff for buying LT vs. P load rated tires? Firmer ride, probably better smooth road handling, worse fuel economy and braking. Each person can decide for themselves on the compromises, but both are safe and acceptible for our trucks.
fishx65 mentions 60,000 miles on p-metric for his truck..thats hard for me to believe. I do delivery's out my 150/4x4/4:10's and have been using 150/4X4 for nearly 20 years being a courier.
P's just DO NOT HOLD UP TO RIGOROUS USE....no freeking way!
Got my Oh4/4x4 in Nov of 05 and now have 51,000 miles on it....somewhere in those miles I tried P's and had to get rid of them before 8,000 or they would have worn out!
USE YOUR NOGGIN...stay with LT'S...a no brainer!
on
Buzzz, I saw in another thread that you had 59k on your truck, is that the reason for this thread?
By the way what type of tire did you get 59k out of?
and did you have any issues?
For those that believe me, they were a set of 265/70/17 113S Bridgestone Revos. I had them put on in place of the stock RTS's the day I purchased my truck. I probably could have gotten another 5 to 10,000 out of them but decided to get new ones about 2 months ago. Went with the same Revos again! When I looked at the Tirerack website it said that the 50,000 mile warranty on these tires does not apply to LT tires.
FishX
FishX
Originally Posted by Raoul
Hard for me to believe too. He only got 60k out of 'P' tires when I got 70k out of my 'P' stockers.
Raoul, I do have 59k and the tires I have are not OEM. They are Procomp A/T's. They have tread, but horrible wet weather traction. I am looking at some Toyo Open Country A/T's and the price diff between P and LT is about $250 for a set.
