Not to beat a dead horse but..... Tire Fit ?? :(
Hi Y'all.. I have searched , read and looked all over but can't find my exact answer.. iI have a2004 FX4 with 18" factory wheels. I have done the 2" leveling to the front end.
Question #1. Will 33 and or 35 fit on the factory wheels and have enough clearance? Will I need the 2.5 spacer ?
Question # 2. If I install a 3" body lift will I need the 2.5 spacer.
Also can I mount the factory 06 20" wheels and tires on this truck with the factory tires on this truck as it sits now and with or without the 3" lift.
If anybody has any pics with the 3"lift and the factory 20" wheels and tires mounted that would be awsome.
Also any suggestions on what looks best with out spending major moola on getting a better look please let me know. I dont do much off roading. Its just for the looks. Thanks in advance !!!
You can fit 33's on your OEM wheels without the spacer. You can fit a 35x12.50 using the OEM wheels and a 2 or 2.5 inch spacer.
If you use a 3 inch body lift, you can fit 35x12.50's with or without the addition of a 2 or 2.5 inch leveling kit.
You can fit the new OEM 20 inch wheel and tire combo without any lift.
