Rear brakes locking up
Sounds to me like you might just be seeing the side effects of some semi- or full metalic brake shoes if you have drums on the back. Another thing drums do is lock up if the shoes are saturated with brake fluid from a leaking wheel cylinder. The tell tale sign of this is a wet line on the inside of your tire after being parked for a period of time. If you have discs on the back, could be a problem from salt getting in and rusting sliders or caliper pistons. Full metalic pads may react the same as shoes after sitting in a humid enviroment . If you are not hauling heavy loads, sometimes it is better to use a cheaper less metalic brake component out back. Just my two cents.
