Anyone have pictures of a 295/70/17 Nitto Terra Grappler mounted on their truck? Need to see how it looks. I know they will fit but not sure if they will be as wide as I want them. Thanks.
Does anyone at least have any input or seen a set up like this? I'm going to be adding a 6" suspension lift and want to make sure I like the results if I'm going to stick with the 17's.
Going with a lift, you may even want like a 315/70/17 if not a little bigger if you can, that'll be a lot more room to fill so do it. I kinda want to see them also, as I am going with either 285 or 295, but no raise etc.
If you need a pic I could take one and email it to you I just had them installed last week and I have a 1.5 auto spring lift. The fit perfectly on stock rims and fill out the wheel wells. I really like them.
