Going Lower in Rim size than the stock?
Is it bad for your truck to go to a smaller size of rim besides your stock rim. I have a stock 17 inch rim and if I went to a 16 inch rim would it be bad for my truck and mess up the warranty at all. Basically how would it efffect my truck in all ways?
on
Originally Posted by treat6238
.... Basically how would it efffect my truck in all ways?
I don't know all the ways changing will 'affect' your truck, the CPU was programmed for 17" when it left the factory so, some things will be different.
One way it will different is it will feel like you added 12 to 18 horsepower to the motor.
Also,
the truck will be quicker off the line.
Slightly higher rpm at speed.
It was governed for top end at the factory and you shouldn't be driving that fast anyways.
If you use the same tires, the truck will sit a half inch lower.
