AFTER MKT Calipers/Rotor combos????
OK, I just did a bnch of stuff to get me go'n faster quicker...
That much is cool!
NOW... I am a lil disenchanted with the brake'n
I have had sum issues with the front passanger side (only 70k on the truck and am on 2nd set of rotors and 3rd set of pads)
I am think'n I want to go with a new front brake set up (new MULTI piston calipers, drilled/slotted rotors and pads) and kill 2 birds... as it were. #1, HOPE'n to eliminate the mystery issue in the pass. side and #2, improve the stop'n power!!!
2 last questions then I'll shut T F up! 1st, if I do this is it a HUGE issue w/mounting the new calipers and get'n em to work w/the ABS etc??? AND #2, do I also NEED to do the drums in back too in order to keep an accurate brake'n ratio??? ...ok question #2.5, I have had good luck with Willwood stuff... do they OR ANYBODY ELSE offer a brake up-grade KIT???
ok guys... THANK YOU for you input.
THX n take care All!
-slick-
SAY! If ya think I'm on crack for want'n to take it THAT far, and feel just the rotors and pads will doo all i need and more, then SAY SO! I am no engeneer, so I know there are like 90% of the people out here that know WAY more than me... so do tell... I'll listen! Respectfully so, no less!!!!
thx once more!
-slick-
