I've been drooling over your truck ever since i saw it in the gallery. Can you give me all the info you can on the 33"? Tires size, wheels, offset backspacing, etc.? Is it lifted or just a level kit?
The way your truck sits/looks with that combo is almost exactly how i want mine. Is it possible with a 08' 4x2 STX with just a leveling kit?
Hi LoneStar
Currently is sitting on 35'' Toyo MT, the leveling was the same on the pics using the 33''s Toyo AT.
20'' Sacchi Machine Gun metal
Brandless(Home made by work shop) leveling kit, I guess is someting like 2.5''
I'm not sure if that's suposed to be the leveling kit's(cylinder) height OR the height it suposed to give to the truck.., which in this case the cylinder's height could not need to be 2.5'' thick I guess.
And because it was sitting like a 1cm taller at the front I added 2 pieces of 0.5'' leaf, which adds a 1'' at the rear. And ended up sitting "perfectly" level( a lilbit taller at the rear which is perfect to me)
Oh, and the backspace I'm not sure so I just went with my ruler, crawled under the front and tried to measure it, I couldn't see the Rim's center edge so I used the edge of the brake disc as reference(the side facing the Rim). I measured 6''.
I do have some rubbing at full turn but not sure if to the left or to the right.
Here's my favorite pic with the 33'' AT Toyos
And that's it.
Salutes
Giorgio
