Will 305/45/R22's fit on a stock 2002 F150 supercrew
I got a great deal on 22 inch rims and now i am looking for a set of tires. I want to buy some Nitto 420s, but I want to know if 305/45/22 will fit or will I have to get 305/40/22's. I know there is no problem physically obstructing the rim. I mounted one and turned the wheel to both extremes. I am just wondering if anyone has similiar size tires on a similiar vehicle, expedition or F150 and if you have had any problem with tires rubbing. Thank you
I did level out the truck with new re-keyed torsion keys, but they fit before the kit was installed. A guy I work with has a 03 Harley Screw and his fit in front and in back with a 2" rear drop kit. You should be just fine. And as Dufunnel stated, mine do rub a little on the front sway bar, only when you max out your turn either way. That may or may not happen with yours depending on your rims back spacing.
