265/70/17 PSI question.
I've spent an hour reading past posts on this, but still can't find the answer I'm looking for. I'm running the stock Goodyears on my truck, and I know the tire sidewall shows max 35 psi, but I'm running 40 psi all around for mileage. I do not tow anything. Is this bad? Anyone else run this? I was running 38, but now I bought the nifty valve caps that let me know if I have 40 in them or not.
Can't wait for new BFGs!!!!
the waring on the side of the tire is there for a reason. DONT exceed it. if it was for a couple miles u could get by but evenutally ur tires are going to wear funny and wear out faster. this cost money plus u could shread that tire hitting something like a curb. my tires have max psi of 44 even towing i dont exceed 40 psi. watch ur tires for wear if they wear on the outside add air if in the center lose air only a couple psi could make the difference between 40,000 miles and 15,000 miles on those tires.
Psi
I would not exceed the recommended PSI on the sidewall of the tire. I run about 40 psi but I have LT tires. Like said above dont go above what the tires recommend on the sidewall. You are asking for a blow out. The tires are not made for trucks in the first place and are the cheaper option. Get LT tires and you can put more pressure in them.
