has anyone tried MT ATZ's on Helo maxx6 (more)?
I ordered a set but they are having problems getting them to seat and balance correctly on the maxx6. They are on the second set of wheels and third set of tires with no luck. Hopefully someone can give me some info. I want to use the maxx6.
Your in luck. The same thing happend to me. I took them to 3 different shops before someone could get them right. They let all the air out and busted the bead. Then they used some kind of a tire lube that looked like brown vasaline to lube the tire and rim. They blew them up to about 100 psi and then let the air back out. They did this like 3 times. Finally they inflated the tires to about 120psi and POP, they were seated. Hope this helps.
Oh here are some pics so you have an idea of what they will look like. https://www.f150online.com/galleries...y.cfm?gnum=6635
