tire pressure?
Careful with that. The larger the air chamber, the lower the pressure needed. With a 33", 35psi is all you need. If you don't haul much, 32-30psi for the rear. Experiment with the 40 psi thing....just keep your tread depth measured on a regular basis to make sure you're not burning your middle's out.
Dan
Dan
You can compare the two tires for speedometer accuracy here.
http://www.1010tires.com/TireSizeCal...?action=submit
