Grinding noise
Grinding noise
Several times over the past week I heard what sounded like the front brake was grinding, or scraping when I applied the brakes. I first heard it while driving slow in a parking lot and I though maybe I ran over a loose object. Today while driving at highway speeds I heard a loud scraping/grinding noise from the front wheel. The brakes worked fine, but I was concerned as my truck is 1 year old and has only 11000 miles. Has anyone heard of a similar problem. Dealer is closed till Tuesday due to the Holiday and Im without a vehicle.
Could be pad are worn if you are really hard on them. You should be bale to check for wear easily by looking thru the wheel at the outside of the rotor and see if you have groves devloping. You can check the back side by looking from underneath. Some time the pads will have "hard spots " ( for lack of a better term) in them that will give the feel of grinding but passes with a little time.
