Nitto Terra Grapplers?
Ok, so question. I've been told by at least one person that I can remember that Nitto Terra Grappler 325/60 R18s will fit under a stock 05 4x4 (as they're basically 33/12.50s, just a bit wider). The real question here is can anyone confirm this from personal experience? And if so what are are your personal opinions on this setup? I'm looking for a setup that won't rub at max. wheel angle or over rough terrain. Pretty much a drop-in replacement without any worries. Any input is appreciated, or other suggestions on drop-ins without worries.
The 04-06's that I have seen with 325/60-18's were all 4x4's with one of the 2.5 inch leveling kits up front. They were also using 18x9 inch wheels with 5 inches of backspacing. So, I know that combo will work. Also, the 325/60-18 is closer to a 34x13.00 than a 33x12.50, which means they are too wide to use on the OEM 18x7.5 inch wheels so you really need aftermarket wheels.
Over the weekend I put on 325/60R 18 Nitto's and they do rub. Mine are mounted on 18'' Eagle Alloy 178. The rub is very minor. The 325/60R 18 are actually 33X13.
http://www.nittotire.com/popup_terra_sizes.asp
Tire size ?? Backspacing is the key
Tomorrow I will put on the Nitto 325/60/18 on 18 x 9.5 Teflon coated black American wheels. As we all know the tire will do a lot of different things on a wider or narrower wheels, but don't forget that the backspacing places the whole setup in the right or wrong place in respect to the other parts...
fenders, brakes, frame, etc...
Lets see if my guy has it right and I'll take a picture at the end of the day after the installation...also the tires are marked with the factory sticker as both 325/60/18 and 34/13.00/18 ...
Chris in Miami
Chris in Miami
Well 2 of the wheels came in damaged so I wont know untill Monday !!
He has the backspacing set so the tires will be about 2" out of the wheelwells, should be ok w/ fender flares. Hopefully they wont rub in the wheel wells accept perhaps at hard lockout turns. Ill be sure to post when it is done...
Chris in Miami
Chris in Miami
Ok Check out the formula for checking tire sizes: http://www.miata.net/garage/tirecalc.html
The 325/60/18 are actually 33.4" and the 285/65/18 are smaller at 32.6"
I am going with 325/60/18 Toyo Open Country but of course I have the 2.5" Kit on my truck and stock FX4 wheels and they will fit the wheels just fine.
