Tires for 92 F-150
Tires for 92 F-150
I have a 92 F-150 2WD that will be used as a ranch truck. It currently has P23575R15 tires on it that are well worn. I want to replace these w/ something a little bigger, more aggressive, etc. The truck will be used primarly off of the main roads on dirt, etc. It will be carrying allot of weight in the bed in the form of a 200gallon water tank.
I was looking at the BFGoodrich A/T 31x10.5 Load Range C tires. They are $100/tire at Discount Tire and I can get $50 back on a set of 4.
Thanks in advance.
Thanks in advance.
https://www.f150online.com/forums/sh...d.php?t=213969
You are 2WD, he is 4WD, but it's pertinent nonetheless. Basically, the same rules apply to your truck. You probably have the 6.5" wheels...the 31x10.50 will work if you have a decent gap of clearance between the suspension and the inside edge of the current tire, about 1"-1.25" gap with the 235 you have now and any suspension components.
