Lubricating caliper slides?
Never Sieze has got to be about the most misunderstood product out there. People use it for all sorts of things that it shouldn't be used for. Here's a perfect example of that. Besides, regular NS will not perform its mission in high temperature applications. Fortunately, there's no heat involved in the brake system!
Rix150
-Joe
And most brake rotors that are coated with an anti-corrosion agent somehow require a 10-lb sledge hammer to remove them from the hub thanks to rust. :dunno
I'll stick with anti seize, thanks.
When you get down to it, anything that prevents a ferrous surface can be called an anti-corrosion agent..... alloy/TiN coatings, rubber covers, plastic bags, cosmolene, paint, under-coating, bee's wax.... you name it.
We did some pretty extensive testing on anti-corrosion coatings to prevent the rotors from seizing to the hubs on the new F-series. We found that a thin layer of anti-seize between the hub face and the rotor worked better than any other coating.
-Joe
-Joe
