Tire Wear....
Tire Wear....
I could use some help here. I have a 2004 SuperCrew that came with BFG tires. 17K miles on the tires and they looks really bad. My last BFG's on my 02 F150 seemed to last longer. What should I expect to get out of them and is anything crazy causing them to wear faster?
Thanks guys
I should have put more detail in my post. Tires are rotated every 5-7K miles. Truck is in proper alignment, at least in my opinion and as for tire pressure, i have the values that give me Green, Yellow or Red indication of tire pressure.
they seem to be wearing evenly but when I compare them to what my old BFG's looked like with 27K on them, they seemed to have more left than my current tires. I have been Dove hunting 2 weekends in a row so maybe all the dust just makes them look bad.
My truck was one that was affected by the vibration. Ford recently installed, new rack and pinion, new drive shaft and some other things. Wondering if the vibrations caused excess tire wear.
Thoughts on that?
Thanks again
Thoughts on that?
Thanks again
Originally Posted by Johngs
Ditto on the tire valves...I remember seeing a few posts a month or so back talking about how they tend to leak or fail completely.
any good, or use the good ol fashioned kind.
Thanks folks
JP AKA RollingRock
JP...most of the digital ones are fine for our trucks. They work in .5 intervals and are usually accurate enough for street and off road. Expect to pay about $15-$20. I keep a digital in my truck. On the other hand, I keep a Longacre liquid-filled guage in the trunk of my Bimmer. But I autocross with that beast and constantly fiddle with tire pressure. I can't remember how much the Longacre was...maybe $50...but again...that is overkill for a truck.
JP
Originally Posted by RollingRock
Thanks for that....do you guys have advice on the electronic air pressure gauges?
I work for Discount Tire Co. I have seen too many cars come in with flat tires due to the Plastic "Red, Yellow, Green" Caps failing. The plastic pieces can break off and your tire will immediatly deflate. I would not trust them. As far as the bad wear....you say you rotate every 5-7 k. Diddo.
However, what are your driving habits? Do you make fast turns? Turn you wheel without moving? Take off fast at green lights? Good driving habits contribute to the excessive wear of tires.
