For Wandell and anyone else
Old 09-09-2005, 08:35 PM
WhitecoltF150's Avatar
Exclamation For Wandell and anyone else
hey man, i was just wondering, when you put on the 285's on your stock height truck you didnt have to cut the front valance at all? and if i go for the 305's you dont think they will rub at all, and when everyone speaks about rubbing what usually rubs
Old 09-09-2005, 10:18 PM
Johngs's Avatar
285's will fit without trimming, and the 305's should as well (on the stock wheels). If you put 305s on with a wider wheel, you might get some rubbing.
Most of the time, for the size tires you mentioned, rubbing would only invlove the valence.
Old 09-09-2005, 10:22 PM
wandell's Avatar
Right, the key is the wheels. I first installed my 285/75-16's on the OEM 16x7 wheels and they were not even close to touching anything. Then, I mounted them on a set of 16x10 Eagle Alloy 058's and they touched the corner of the front bumper's lower valance. I had to trim about a 1/2 inch of plastic off for clearance. Wheel width and backspacing are as important to fitment as tire size.
Old 09-10-2005, 08:59 PM
Cool perfect
thank you both, and now i just have to make my decision whether to go for the 285's or 305's but thanks a lot guys
Old 09-11-2005, 10:09 AM
KickinBlue4x4's Avatar
My 285's rub on the valance. They are on 16x8 wheels.
Old 09-14-2005, 09:05 AM
Mange's Avatar
On my 2001 Screw, I put 305/70-16's on AR Python 16x8 with no rub or lift.
Quick Reply: For Wandell and anyone else
