17in Rims and 33in tires?
There have been some problems with aftermarket 17 inch wheels on the 05's. Aparantly, early in the model year Ford changed the brakes and now some aftermarket 17's won't fit over the brakes. Before you go to the trouble of mounting and balancing tires on 17's, be sure to test fit one to make sure it will fit over the front and rear brakes. You shouldn't need a leveling kit to fit 33's unless you go with a really wide wheel or one without enough backspacing. However, it would look better in my opinion with a leveling kit.
