fixed brake line rusted out
Just remember that a steel line should be replaced with steel. Have seen people use rubber lines with hose clamps ( if you can beleve it... I think they should license people to work on brakes) Replace the whole line from connector to connector our use a flareing tool to put proper connectors on your splice repair.
Brake line
Easy to fix, I just had the rear line in my 97 go last week. Rusted through above the differential on the drivers side just ahead of the connector. It is not expensive, and not hard to do.
I replaced it from the back (std 3/8 male) to the front under the cab, by the fuel filter. The front fitting is a metric male, I can't remember the size.
I bought two pieces of brake line and coupled in the middle, it easier that way. The whole thing cost about $20.00. Remember you'll have to bleed the brakes, so make sure you can break loose the bleed nipples.
I hope this helps!
I hope this helps!
Originally Posted by bmx150
where can i find the steel line that will be cut to length???
i just did mine, '91 f-150 4x4 front to back. normally i wouldn't give NAPA a nickle but they had all the lines i needed. under $80. keep in mind these are "inverted flare" fittings on purpose. it's a pressure thing and thats why a place like auto zone etc, doesn't sell 'em usually pre bent. god forbid a brake fail from a yard mechanic like me.... imagine that law suit if someone was so inclined. And spend the $30 for the bending tool. hands work, but the wife screaming you are using all he good towels to ease the bends is way cheaper than the divorce lawer
