f150 turnstops for lightning wheels
this post is not needed!!!!!
i'm wondering if anyone out there who is using these turnstops could tell me where they install. more than that i would really like some dimensions of the stops. as far as i can see the kit is not worth the forty + dollar price tag. the kit i saw had two bolts two pieces for the stops, locking washer and some lock tight. i'm pretty sure i have everything i would need to make my own kit and for alot cheaper. thanks for any help. also if anyone might have some lug nuts for a lightning laying around i am looking to buy a complete set.
the number for the kit is m-1010-L
Last edited by travytrav; 09-08-2005 at 09:58 PM. Reason: there are no replys and i have alread solved my issue
I have this kit on my truck. It should be pretty straight forward to make your own, because they are pretty much as you stated. They install on the backside of the A-arm in an existing hole. They don't keep my tires from rubbing just because mine are larger than the lightning, but they help some.
