Brakes pulling to right when hot.
Hello All;
I haven't been here for a while. I used to use the name "GlennMc" but lost my password and changed e-mail accounts so I had to re-enlist. I used to stir up a fair amount of heat on the towing forum by challenging a lot of misconceptions about legal towing limits.
Todays question is about my brakes. When my truck (1998 2 wheel drive rear wheel ABS) is cold, the brakes work fine. They stop well, straight and with no vibration. When I drive around the city and warm the brakes up, it starts pulling to the right when I apply the brakes. The longer I drive the worse it gets. The right front wheel is covered with brake dust and the left is not. It also starts to squeal from the right front when it gets really hot. The rotors, calipers and pads are new. I am wondering if the pads (napa auto parts) are the problem? Anyone else ever experience something like this? Any suggestion is welcome.
Thanks, Glenn.
Thanks, Glenn.
Yankee 7985;
Would the caliper get worse as the brakes heat up? It sounds logical if a piston is expanding as it gets hot and sticking in the bore. If it is, this will teach me again that aftermarket parts are not the best bargain in the long run and that I should have stuck with OEM parts. Thanks for the reply, Glenn.
Re: Brakes pulling to right when hot.
Originally posted by McGlenn
Hello All;
Thanks, Glenn.
Hello All;
Thanks, Glenn.
From the posts mentioned it's either 1. Caliper or 2. Brake hose.
Which is easier/cheaper to replace?
I had 206K before any brake line failure. The failure was a clog in the line, and I suspect that there was corossion (sp) built up inside the hose bracket and actually crushed the line at that point. The clogged line didn't seem to be causing any pulling problems though, I just couldnt push the caliper pistons back in during a brake change.
Originally posted by Mr_Bentwrench
i dont have a picture but if you turn the wheels all the way one way you will see the flexable brake hose one end connects to caliper and the other to a bracket and hard line. i beleive the hoses run between $15 and $30 depending on where you go.
