Larger Tires... but not too large
Hi,
My stock P255/70R16 Generals are due for replacement anytime now. Went to the Costco site and their "tire search" results indicated that I could go with a LT245/75R16. Is this a larger tire? Right now, the Michelin LTX M/S is my current favorite. I'd like to go a little larger and wider this time around but not to the point of overdoing it. Any suggestions?
Thanks...
Thanks...
You didn't mention what motor you have, but be prepared for a loss in accelleration and mileage with the wider, stickier and taller tires.
I went with a 265/70/16 replacements for my 255/70/16. Calculators on the web showed the new tires were supposed to be 2% taller than my original Generals, but they actually were 5% taller.
Very noticeable drop in accelleration on my 4.2. I was expecting better fuel mileage due to lower revs, but my mileage (even after adjusting for the 5% speedo error) was down, too.
The bigger tires look better, and the stock Generals sucked, but if I were doing it over I would go with my stock size.
if it is 2wd, and I assume it is given the stock tire size, I'd go with something around a 265/70/16. Had a friend with 265/75/16 and it looked too tall for the truck. 265/70 is really only what I'd call one size bigger, and would look nice, buit not be too big, and most likely wouldn't affect speedo calibration or power noticably.
Originally Posted by Crewd
Is the Michelin LTX M/S still popular around here?
I went with the Micehlin Cross Terrain SUV in 265/70/16 when I replaced my Generals at around 60,000 miles. The Cross Terrain is a "P" rated tire. It may give up some load carrying capability to an LT tire, but it easily exceeds my trucks ratings. Sidewalls seem quite soft and thin, so if you offroad in rocky areas, you should probably get something else.
The Cross Terrain was a huge improvement in ride, cornering, wet weather and dry traction over my OEM Generals. It also is much quieter than my stock tires. I have about 35,000 miles on them now and they look like they will last a long, long time.
